Fuel Mixture Screw
mikebru
Hey Guys - Where can I buy an adjustable fuel mixture screw for a 2005 TE450? Has an FCR. Thanks.
I've searched around and found maybe a Zip-Ty and something from JD Jetting.
Thanks for all of the replies. How about the R&D one that stretches around to the side of the carb. like the idle adjustment type?
Kreig is right, get a good one. I just spent 2 nights kicking the TC to life with no luck...justed changed the fuel screw back to stock...and its back to life.
For no reason, it went from working good to nothing. :banghead:
krieg;101878 said:
Don't waste your money. Get the flex jet fuel screw. Works great. No burned fingers. EASY easy easy.
Couldn't you simply put a short piece of hose on the end of a regular adjustable fuel screw?
I've seen 2 aluminum fuel screw *not* work because of the diameter of the threads were too small. I seriously doubt it was because they were made of aluminum, probably a bad batch of fuel screws made by the same company. If they were not secured with a wire to the bike they would simply fall out they were that bad.
I used a Scotts but I'm not sure it makes much difference as long as they fit. :)
