Fuel Line for Fuel Injection
Navaho6
I installed an in-line quick disconnect on my '09 TE610 since the oem disconnect leaks as soon as you pull it apart. I removed the larger fuel line and replaced it with some of the vent tubing that came off the anti-smog can. Everything works fine right now. However, I noticed that the oem fuel line has a plastic liner on the inside. The outer rubber hose is just for protection.
Shopping Sudco today for some vent line, I noticed that all of their polyeurethane fuel lined is labeled "not for use with fuel injection". Should I be using a special line for the FI system?
You can usually find fuel hose line that is rated for fuel injection at any auto parts store. It is designed to withstand higher pressure than standard fuel line.
