Fuel line as replacement for Oil breather line??
ripnriding
So, decided to pack up trailer and head out to some local trails about an hour outside of town where I usually bump into some other likeminded riders to play. Was juuuuust about to pack up after some relaxing meandering around some amazing single track when a guy pulls in with a single bike.....sure....why not head back out....of course tired and wanting to get some time in resulted in dumping the bike a few times with the major culprit being a tight steep sand climb. "Damage" was my oil breather line melting and dumping a wack of oil on mid pipe (area of line that melted) and into the airbox...Gingerly got back to trailer and created a mental list of things that need to be tweeked prior to next ride.
After removing and bringing this original, now inflexible melted line to small engine shops, LBS, and automotive shop...found a line that would work for replacment...it's fuel line...question....is this beefy enough for replacement of the oil breathing line that goes from head to air box?? I'm thinking this line really doesn't carry oil unless overflow or upside down (essentially how I ended up on the sand climb). Another solo ride planned for today and just want to ensure I don't end up with a catastrophic while out there...thanks in advance for your opinions
The difference between fuel, oil, and trans hose is temp, and resistance to chemical breakdown. Oil lines tend to be oil resistance, but lower pressure then modern fuel injection line. That said I ended up using fuel line for the zip-ty bypass and it's been fine.
