I had the clutch cover off to put in a new clutch pack and to adjust the clutch play for proper engagement at the beginning of summer and then got caught up in a relocation due to work. It was left dry and I just got around to putting in oil today. Started up on the first kick, seemed to idle just fine, but after a few minutes I noticed foam rising up the crank case breather tube. Shut it off immediately. Removed the oil filler cap and nothing but frothy oil inside, anyting other than blown crank seals that might cause this?
Seems obvious, but before I start tearing it down just thought I'd get confirmation from the experts here.
Thanks
Adam
Thanks
Adam
