Front Brake Failure
dibblego
I have had the front brake progressively fail, where now I can squeeze the lever as if the bleed nipple is open. I have changed over the master cylinder and reverse-bled with no difference, so I am starting to suspect the seals in the caliper.
Can anyone suggest any other possibility and what might be required to fix it? Cheers.
Here's something to try. Put the bike on a stand, turn in the front brake adjusting screw on the front brake lever all the way. Now back it off 1 turn. Take the cap off the master cylinder resevour and make sure it's 2/3 full. Put the cap back on. Now grab a roll of black tape or a rubber band, pull the front brake lever in 1/2 way and tape or rubber band it in that position overnight. Tomorrow you can free the brake lever and you should be able to bleed the brake from the master cylinder side. Sometimes I find it necessary to do it this way to get tiny bubbles out that are very stubborn. Your caliper is most likely fine. Good luck!
sounds advice. had an issue bleeding the 6 pots on my ninja. I have used this method many times with success. but I tape the lever fully to the bars. it's important that when you go back to it in the morning release the lever and leave it 10 mins. this allows the bubble to make their way to the top of the reservoir.
