Front Axle nut replacment options?
I'd much rather have the larger 15mm for an axle nut than a 12mm. More robust. Perhaps less convenient, but convenient doesn't save your ass when you round off the bolt because it was undersized for the job. I do like the idea of a 27 and 15mm spoon set, though.
No disrespect, but I have never rounded out any size nut or bolt with a 6 point socket or box end wrench, that takes the wrong size and bad talent. Would love a set of spoons though, you can eat a snack on the go also.
I'll loosen the nut and tap it as far as it will go. Then I'll use a socket that fits the inside diameter of the fork dropouts to gently tap the res of the way out.
I have an aluminum round bar I use to push it out. Keep it clean and well lubed and it will come out EZ.
