Kenneth Webb
Livin' It Up!
Tried to install my new FMF Q4 and mid-pipe just now, and so far it's a no-go. Maybe someone else has had the same problem.
Mid-pipe slipped onto the headers OK with minor help with a few taps, but the angle at the muffler end is way too high. The mid-pipe hits the engine case and the muffler will not slide on as it's way up from where it needs to be. Next step is to loosen the headers and try to rotate them up a bit to see if that will raise the front of the pipe and angle the muffler end down. It doesn't look like that's going to work, but I haven't tried yet. Also, the muffler will not slip on far enough to let the mounting bracket hole align with the frame mounting tab.
One more try at the headers and then I will have to consider cutting the mid-pipe and the stock mid-pipe to join at a better angle and then have the joint welded. Shouldn't have to be doing this!
The FMF is sure a lot lighter; 13.15 pounds less! It is going to work one way or the other but I am wondering if I got a mis-bent mid-pipe. Any thoughts?
I also discovered that my left hand lower sub-frame bolt was missing! It must have backed out on my recent long, 2200 mile, trip last month. I guess the right hand bolt was doing it all, and I never noticed any problems even with a full load in my saddle bags and duffel on my tail rack. Bolt had Loc Tite, too.
