Fluid recommendations 1976 360 WR
I tried tractor hyd. fluid but I like atf f type transmission fluid better. Napa still sells it , its for older fords .
There is a belray product if you want to go to a bike shop. I would have to look at a bottle to say for sure at this point. I think that is what most origional owners used.
If you use "engine" oil you are supposed to avoid the energy conserving stuff as additives are said to be undesirable to the clutch parts. Motorcycle specific engine oils take the clutch into consideration and generally state that. I have red cap Mobil1 in the four stroke 510 most of the other cap ones have the energy conserving label. It may well by now I had a number of bottles.
i have run atf type f off and on. it is definitely provides the best clutch action and shifting. i usually run shell rotella blue jug 15w-40 or amsoil 10w-30 motorcycle engine oil. changing to steel friction discs drastically improved the looks of any oil after being run 4 hours..
