Flashing light neutral three times short one long. Bike will not start.
Mikhail
Husqvarna SMR 510 (2088 y.o.) stalled on the go. It will not start. Flashing light neutral three times short one long. When the ignition on - fuel pump does not buzz. Took out a fuel pump, is connected directly to the battery - it works.
Petrol in the tank is present
Spark at the spark plug is present
Starter turns, but the bike will not start.
Help identify the problem please.
There are no clicks when i turn the key to ON.
it is the fuel pump relay cause of the problem?
how to check the relay, where to find it on a motorcycle?
If the fuel pump wires are shorted out somewhere, the relay will not click and the pump will not prime. I have no seen where a relay has failed, it is usually a bare wire that is shorting out somewhere.
Approx. Thank you. We seek an open electrical circuit. A fuse may be causing the problem? Or would then dashboard did not work?
The problem is solved. Indeed fuse. In appearance looks quite normal. Just do not think that the problem may be a trifle)))
