Finally got them installed.
Mike-AK
The problems I had before was because I was tightening the bar end bolt before snugging down the bolt that attaches to the top clamp. Fits great when you do it right.
Neither. I replaced my throttle tube with a G2 Throttle Tamer.
Does the tamer tube extend past the end of the handlebar and then make a 90 degree circle at the end, creating a cupped end to the tube, like did you drill a hole in this to accept the HDB bolt
G2-TCO-KTM-4ST_is
OR does the tube just end, without creating a "cover" at the end of the handlebar, like this one
The G2 tube has a cap on the end that you can remove. It is just held in place with an o-ring. After you remove it, you need to slide the throttle inboard enough so the handlebar protrudes a bit past the tube for the hand guard to snug up against when you tighten the bolt.
