• 4 Stroke Husqvarna Motorcycles Made In Austria - About 2014 & Newer
FE/FC FE350S Power Commander V, R&D done
robertaccio
Well my crew member's 2015 FE350S was/is the set up test mule for DynoJet Research to do their PC5 integration. He just called to say they are done and he is heading back from Las Vegas, with a brand new powercommander 5 plugged in.
Bike has been tuned with an FMF powercore slip on muffler with the S/A plug in (the one with the carbon fiber end cap)
bike was mixture (A/F ratio)close at low rpm, at 40-60% tp it was scary lean and it was fat way up in high tp. My opinion for the high TP fat is that they tune that wot position like an accelerator pump.
Anyway they got the fuel metering clean and clear throughout the TP so its still a hardcore enduro with smooth torque power throughout, oh yea with this set she makes roughly 3HP more from top to bottom smooth power curve on the dyno. The bike is now optimized.
The FE350S PC 5 should be in the catalog asap.
Where can I get more info about the PC5 for the husky?
From DynoJet/PC5 directly and/or from ZipTy Racing as well.
Although DynoJet installed and Dyno d the system, ZipTy actually made an even further tweak adjustment for the "accelerator pump" feature in the PC5 to get zero lag more snap from rapid throttle transitions.
