Fail - Te449
domrvt
I know this has been mentioned before and most people say to ignore it. I'm curious if anyone has any more insight on this Fail message. On a street ride this morning (2011 TE449), I stopped for fuel and after starting the bike again I had the fail message appear. It would not go away with a power cycle of the ignition. I rode 20 miles showing Fail. Does this put the bike in some sort of limp mode? I always run Race Map II (with JD), does the Fail message revert this to the standard map? Bike seemed to run like normal so I'm assuming everything was running as it should.
On a side note, and probably directly related: first start of the morning the bike will fire easily. After stopping, then starting it again I need to give some throttle to get it started. And Fail appears. What's going on here?
Thanks,
Dom
Has it always been like that or just recently turned on and stayed at Fail? Wonder if water on some wiring could cause short circuit and be the culrprit?
I have a 2010 TE 250 and never had the fail message stay on the dashboard...but know others have.
I get a fail once in awhile on first startup of the day. I let it go completely off, then restart, never after initial start...
does not happen often, bike runs GREAT!
