Factory fork heght in clamps 12 TXC 310
need2boat
Bought the bike second hand and the PO had them set to 10mm but I've found 5mm works better for me in the south NJ sand. I looked though the manual and couldn't find any factory guidelines. I understand the Pos/cons to raising and lower them just wasn't sure of the range.
Also interested in what others are running.
My 13 TE came with top clamp at 3rd ring from top of tube or 18mm or so. Never moved it as was not an issue when initially road tested at speed and worked well in the tight stuff. I don't ride sand fast but figure for others it can be tailored to slow steering as needed. I tend to adapt to whatever I run anyway. Being 165lbs. also only adjusted compression back one click from stock on the fork. I figure my weight is target for most bikes.
OK, good info. I was thinking stock was at the first line (from top) around 5mm. I'm about 170 without my gear on.
5 mm is good for sand with stock springs.
The older Husky's liked the front end lower..like 20mm even but not the newer bikes.
@ 170 you should consider softer fork springs.
Do you ever bottom the forks in the whoops?
So I'm leaning a bit more about this after I posted.
The PO had out the springs/forks to FTI in NC. I rode it last year as we are about the same size. I called them in January and decided to send back to them for oil/seals adjustment as they were free I just called them and they explained how to read the sticker and said I should use the 5mm. As far as the springs I think it was replaced for the previous owner who was about the same size/weight as me. 170ish. It lists the springs and other info but since I don't know stock I'm not positive.
I was happy with the way the bike rode when I raced but honestly I don't have a ton of race time or experience.
