I replaced my sprocket due to excessive wear, and after 2 rides it looks like the sprocket is excessively wearing on the inside of the sprocket. (original sprocket pictured)
I have confirmed that the wheel is centered (used a ruler), swing arm has no play in it. I have yet to confirm that the sprockets are aligned, that will be next. My rear suspension really sags, I am having it re-done by Lt-racing, not sure if this could play into excessive wear.
The really odd thing is the wear on the sprocket isn't even around the sprocket? I spun my tire and used a straight edge against the rear disc brake and there is a very slight gap between the straight edge and the brake and I am curious if my wheel is not True? Would this cause the sprocket to wear?
