Engine Intermittently Sputters, Backfires, and then blows a fuse
dirtdiva
Anyone have any ideas - Hubby and I went for a ride today and his bike was running great. Got up into the mountains/fog/light rain and suddenly the bike started to intermittenly cut out while at speed. A twist of the throttle seemed to clear it up. Happened again a short time later. While at lunch, his bike sat in the rain/snow for an hour or so. After lunch, the problem persisted on a more frequent basis (riding in steady rain/hail/snow), now with backfiring and he finally had to pull over. Lucky me, I got to sit in the cold rain and wait while he took my bike and fetched the truck.
Got the bike home (still raining), tried to start it - fuel pump primed but bike wouldn't start. Tried again and heard a pop - appeared to blow a fuse. Now no power at all when turn on the key.
It's a 2009 TE510 with full powerup and IMS 3 gal tank.
It is probably electrical-intermitant. Go over your lines and make sure all connections are firmly in place.
Agree. Take a good look under the tank at the harness, especially where wire could be pinched or passing over a sharp edge such as a bracket. Also look behind the headlight, and make sure your battery terminals are tight.
Intermittants like that are often a vibrating or pinched wire just starting to wear through the insulation. In time they will wear far enough to short, maybe blow a fuse, or become not so intermittant, but easier to find :-)
This is from DanBartol's 510 thread:
"Got the bike back today and the problem was an intermittent electrical contact between the coil and the spark-plug wire."
+1 Coil connections is a good place to look for the running problems. Coil ground connections.
Also - straightforward but check the circuit related to whatever fuse blew...
