Engine breather
mike54
Has anyone removed the breather hose from their air box and blanked off the air box hole?
I replaced the shock on mine last night and the air filter was black around the breather entry - what a daft idea to have that, no doubt for "emissions" reasons. I'm going to just re-route the hose a little and maybe put some kind of valve on the end of it. Otherwise the engine is spitting crud and hot air right back into the air filter
No. What is blowing onto the air cleaner is mostly oil discoloured by traces of carbon. There is nothing there that is going to hurt anything and at least you can be sure that part of the foam filter is oiled. It can also be used as an indicator of engine condition.
The vacuum created by the intake also serves a scavenging function for the crankcase pressure. It isn't just emissions.
