James Patton
I posted recently that when my MY12 TE511 got hot it would not start (turn over). Bike ran perfect,
started fine cold or warmed up. Just when hot enough for fan to run, bike would start to turn over then
stop, as if battery was low, or mechanically binding. What I found was that the starter solenoid on the
print shows a overload, and when it is to hot this opens up, stopping the starter from turning. Initially
an amp clamp showed this, and jumping out solenoid confirmed it. Going to try a new solenoid, but believe
The culprit is heat conducting back up from starter, and am installing larger wire on solenoid to starter,
And all starting circuit wiring. Keeping speed up on these bikes seems to let enough air to run over
front of engine to not allow this fault, but the single track,1st gear stuff I have been doing really does
get bike hot. I know these bike are not really for this type riding, but have been surprised how well it
performs this slow speed stuff since the ECU upgrade and the EF coolant.
