electrical - fuses maybe?
blakebird
in November I had my 2012 TE 310 off getting the suspension done....got it back and got busy at work....Winter rolled in and riding slowed down - so the bike has been sitting on the lift waiting for me to get off my lazy ass and get it ready for a Feb Baja trip.
I swapped chain/sprockets, sent the seat to Seat Concepts, wired up some accessories, etc.
Took my time.:D
Battery's been sitting on the workbench on a Tender while I tinkered... today I put the battery in and hooked up the taillight & rear turn signal connectors.
Turned on the key and got the fuel pump priming the fuel rail... 5w running light in the headlight shell, and a taillight with all LED's firing.
First thing I checked was the brake lights - nada.
No horn, no turn signals, no brake lights.:thinking:
Starter engages, but since I hadn't put any gas in it yet, I didn't fire it up. No headlight, but that won't come on until the engine's running...
Don't see much in the way of fuses - the big one at the starter relay, the two 15w mini's and 20w mini on the right side that clip to the battery area of the fender.
Did I miss one? Am I missing something else? Took all the Molex connectors apart and re-snapped them together, checked them for clean connections...
Probably something simple.
Hard to believe I hadn't noticed that before - and it sure didn't seem normal, but those and the horn and brake lights do indeed need the engine running.
Put a gallon in the IMS tank and fired it up finally after a month sitting on the stand. All's well.
