EHS Universal 4.5 x 4.5 Filter on a SMS 630
4l0
Just ordered one tonight from USA.My bikes fitted with Husky Arrow pipes and ECU, and a P/U kit.Will it be ok to fit EHS Filter kit before i can afford a JD Tuner.Was going to purchase JD over winter, and get bike serviced as its only covered 400 miles at minute.
You will most likely be lean, does your bike pop on deceleration now? If so, it will only get worse.
Lean means hot, which is bad for your valves.
  • Like
Reactions: 4l0
RDTCU nope its not popping at all.Wont fit it yet till i get JD Tuner later in the year
Have the filter on my 630. If there are any problems (there weren´t on mine), you can adjust the fuel/air mix with the Jd tuner. The only thing I´d advise is to take good care on getting the angle right (which I didn´t). I´d try and get it level with the ground and not with the top of the air box. And definitely get hold of some nicer button head screws.
Rehashing this thread to post a few comments on the EHS pre-filter...
A year ago I put holes in my airbox cover but, I didn't like the amount of dirt that was getting in. So, recently I bought a new airbox cover and installed an EHS pre-filter.
With the EHS pre-filter installed I noticed two very slight, but nice improvements all the same. First, I get better throttle response at low RPMs. Now, when I'm riding in the dirt, I feel less of a need to downshift when the RPMs get down to around 3000. The EHS seems to allow the motor to lug more easily. Second, prior to the EHS I still had a slight surging feeling when cruising downhill and having the throttle cracked open just a small amount. Now, that surging sensation is practically all but completely gone.
what bike you got buddy and set up?
SM630 | Leo Vince Full Ti Single | JD Jetting Power Surge | EHS Pre-Filter | 14/40 Sprockets
spot on:thumbsup:.Im running P/U,Twin Arrows and ECU.Got a EHS Pre-filter coming and about to order a Jd jetting power surge,and fit them over winter months.
I have the TE and find myself in the wet and muddy quite a bit. I wasn't happy with the amount of water that was getting past the EHS, so I put a stock airbox cover back on.
Funny I ride wet and muddy plenty also and that was the main reason I installed an EHS. I had the air box drilled (under side panel, not out in the open) and snorkel removed to increase air flow and that was allowing easy access points to the airbox from the rear tire flinging mud, dirt and water. Especially got worse after switching to a single exhaust, prior to that the right side muffler blocked the direct path quite a bit. So I bought a new stock airbox cover, kept snorkel attached and installed an EHS. Roughly the same airflow but now I have better protection from the elements. When washing my bike (seldom done) I used to be paranoid about spraying the EHS and covered it with blue painters tape. But did an experiment once and sprayed directly onto the EHS with low pressure garden hose and no water got inside. Even if some did most would drain out and/or evaporate and not suck past the filter to the engine.
_
_
I don't know if my filter needs replaced or what, but I stuck mine in the sink and put some water on it, and quite a bit passes through. I also see water in my airbox after washing, and this is with a low pressure garden hose and a shower nozzle.
Could be, I know yours is older than mine. Before installing I did the water test on mine and nothing passed through. Not sure what the lifespan is on these and if the fabric weave opens up with age or not.
Just checked, mine was installed in February. So 7 months and 6,500 miles. I think I'll put it on an annual service interval to be safe and replace it every year. Only $15.
_
