11TE310 has one- http://www.cafehusky.com/threads/2011-look-what-ive-got-no-dirt-on-yet.13935/page-2EFI bikes don't have petcocks.
11TE310 has one-
I pulled the pump out, it has been wired down by the previous owner. The pump primes when the red button is out and after the engine cranks. I have a strong spark on a new plug and fuel is getting to it but it won't even pop. It acts like the ignition timing is off. I am looking into TPS and other sensors that affected timing.Fuel will dribble out of the red 90degree fuel line connector when you disconnect the line. The more fuel you have in the tank the more it will dribble. The weight of the fuel is forcing it out. If you are having trouble getting your EFI bike to run and you have not ever taken the fuel pump out, I would go check that. Even if it is priming, if it has "unseated" (common problem with the EFI huskies) that will cause the bike to stop running. It is an easy fix, just use some Stainless Steel wire to secure the pump in it's "nest".
I just did a tank swap and moved my pump over to the new 3 gal tank and as usual, it pukes some gas when I disconnect the fuel line.
Search on here, there are plenty of threads about it and plenty of us have been effected by that same issue. It happened to me in a race. Got home, dropped the fuel pump assembly out and sure enough, my pump was about 1/2 inch out of it's nest. As soon as I safety wired it in place, have not had a single issue since.
My cam timing is right on, I'm finding there is much more to ignition timing than the carb bikes. Something is telling it to spark at way out of time. Does anyone know where the flywheel picks up a signal for the crank position sensor?i just had a problem with hard starting on a new 630, dealer upgraded clutch rod and cam tensioner,
somehow got timing out 3 teeth. it was very hard to get started.
