ECU removal (TE310R)
beck
Help.
I am attempting to remove the ECU to send out to have it reprogrammed and I am having an issue with removing it. Simply, I can't figure out how to do it. In review of the shop manual it shows that it just comes unplugged, I have pulled on the device (secured the wires) and it does not budge, I figure that there is a clip or some sort of trick to removing it.
If anyone has some advice, that would be greatly appreciated, so that I can get this shipped out to Zip-Ty ****************************************
Thanks
If it's like the 2010 then it's mounted on a rubber bracket and connected to a tab on the frame, have you removed the tank? You'll need to remove it to get the ecu out easily.
I have pulled the tank and can release the ECU from the rubber stay, what I am struggling with is removing the ECU from the wiring harness, I fear that I am about to break something because I can't find a release clip.
There are multiple rubber fins on the male part of connector the to keep a watertight seal, they do take a lot of force to separate. I think I used a screw driver to lever the initial few mm then it came easier, I can't remember if there is a release clip or not though.
