MZee
I'm learning about the possible ecu fixes for my new 310R. I have heard / read that the magic box can be removed & sent off to be reprogrammed. I have also heard / read that the whole bike has to be taken to a dealer (3hr drive) for the fix. Which is true for the '14 310R ? Im not a racer, but a dualsport / trail / adventure rider. I dont need more power, but want to fix the low RPM die-out and the high RPM power fade. I have removed the catalyst, and drilled 3/4" holes thru the filter baffle. This helped the mid range power, but the low & hi RPM glitches remain. Does the metal screen between filter & throttle restrict flow much? What are the ECU /mapping options available?
Thanks
Thanks
