1982 XC 430
So what I want to know is can I use the CR Swing Arm that was pre ITC on a 84 ITC Frame using ITC Shocks. The upper Mounts sure moved but did the bottoms ? What I am trying to do is convert the suspension to full travel CR Specs.
I was also surprised to see that the 84 WR has Betor ITC and not Ohlins. The Ohlins in the Pic are some I picked up on e-bay and I assume they are 83's and are fresh rebuilds from WER and I had Drew set them up for full length which they were all ready. ( they were Blue when I got them, I changed the color ) I was also surprised to see the 84 ITC shocks are the same full length, and not shorter. This bike is a very little used WR with the original Tires still on it, Short Fork Legs.
So, once again will I be OK using the Longer CR swing arm on the WR Frame to convert it into a CR. I'm going to say no, it won't work. The shock mounts are further from the Swing Pivot point, which is going to lower the Bike. The Swing arm is a bit longer, but not nearly enough to get it back up to CR height.
