e start 2012 te310
Phil Lamb
Folks-
The question is whether e start in gear is just not to be expected. Easy to start in neutral, exhaust valve adjusted to tight spec, Mobil 1 0w-40, little to no clutch drag when in gear with clutch disengaged. Shorai lithium iron battery fully charged. But it will not e start in gear.
Thoughts, comments?
Thanks, Phil
My 2012 TE310 doesn't enjoy being started in gear if the engine is cold or really hot (think single track in summer). If I am running in very tight snotty single track and stall the engine, it doesn't like to restart and stay running in gear with the clutch in. When mine is cold and I start it in gear I feel the bike lerch a bit with the clutch it but it usually stays running. I try to restart in neutral if time allows. Sometimes when I run the enduro races I am pressed for time so anything goes then... I also run the 0w40 and it does help a bit but doesn't eliminate the issue. My plan is to add a Rekluse this Christmas.
I am still running the original stock plug, which looked fine recently. Cannot tell you what it actually is. I have an iridium NGK CR9EIX over 3521 on hand, purchased from my local dealer, as a replacement. 719 miles on bike.
Tinken, on the oil return line mod I have previously mentioned, I went to a 5/16th by 1/2 inch clear tube, about 28 inches long, secured to the left bottom frame rail by the 2 existing flexible tabs, plugged with a bolt and hose clamp. It is accumulating the same type of "spooge" which accumulated in my Honda Trail 90 tube (the first real dual sport).
I can live with this starting issue, if need be. What really transformed its performance is the 12 port injector and TXC ecu. I adjusted the mechanical throttle stop a bit, but no new I-beat or tps tinkering. At 62 and new to motorcycles, I am not pounding this machine.
The CR9EIX should be installed and the oem discontinued. The oil return mod is coming tomorrow or Monday.
