Drive shaft question 390 CR 1980 (I think?)
VTF
I have recently bought a 390 CR and lots of spares. The output shaft in the engine on the bike, emerges from the bearing with only the splines visible - no smooth surface for a seal to mate with. When I consult the parts diagram, I notice there is no seal in the flange, only what is described as a 'distance ring' part # 16 12 353-01. In my spares, I have found a plastic ring, a little smaller in outside diameter to the internal flange diameter. There is no way this is going to make a seal that stops the gearbox oil escaping and the water and dirt from getting in. Can somebody help? Is the wrong output shaft in the engine?
You have the beginning of the tranny upgrade that husqvarna did at the factory. The engine cases started evolving to the newer 82/83 case as we know it. My '81 cr250 had the same setup as yours. It's the few years of the evolution of the engine cases.
The distance ring is the plastic spacer.
On the output shaft bearing the bearing had a seal on one side of it. The plastic ring is a spacer. There's no seal there but on the bearing races. Your outer seal on the bearing is missing.
I noticed these seals on the output shaft bearing would have running seepage from wear and Mark the spot on the garage floor. The area on the tranny would be wet too. When the seal is still present I would silicone the spline on the spacer. It would cut down on the leakage.
Now the HVA offers a end cap flange with a seal and spacer to stop this seepage.
Go to, www.husqvarna-parts.com/
Click on the, engine/clutch/tranny. Section.
On the second page it's the;
80-88 eng brg counter shaft
#29-31-265-59 or 73-82-205-28
There's a pic of the bearing out put side.
Thanks for the information. I just phoned Andy at HVA-Factory and collected one from him in person. Excellent :). Now let's see how she I get on with her racing this Sunday :D.
Don't forget to post some race day pictures and or video, let us know how you do!
Ohh, if Craig doesn't, then there are several of us who will :D
With the entry on Sunday it will be an awesome meeting. Hopefully Craig will have some on-board footage !
