Does anybody have an error code list for TE250, 2011 model
Bong Jae YOO
Going through the threads I guess a lot of us have the same problem.
I have a E41E error code showing up when key is turned.
Of course it goes away soon and it does not appear whilst riding but I am uncomfortable that it came up in the first place.
I noticed some threads mentioning that it always shows up but do not know why.
Hence I would like to ask if somebody has or knows where I can get my hands on an error code list.
Any support will be much appreciated.
Thank you very much.
It's not an error code - it's the wheel size setting for the speedo.
There are no error codes shown on the dash, just the word 'Fail' will stay on with the engine running if you have a fault.
You may see fail occasionally when first turning on or starting but as long as it disappears shortly after you have nothing to worry about.
Dave
That's the first I've seen that explanation. I've seen others here on CH......
"I think the code you see is the softeware version number for the dash "
"That is right on the dash readout on code E41E "E" stands for ENDURO.. I believe the SM's are seeing "S" as the letter.."
".. reading here the "E41E" is just an identifier code for the model bike."
In essence the explanations are the same - the only difference between the Enduros and the SMs in relation to the dash is the wheel size setting. Everything else is the same, assuming you are comparing the same type of dash.
Dave
