DIY head porting. Thoughts?
Dwahl
Hello everybody!
Bike is an 05 tc 250, with a 300 kit. just a little curious about trying to get a little more air flow. I know its not all about making the port bigger there are other aspects involved so if you know them please elaborate. My friend has a ttr 225 that i'm fixing for him, its a real junker so i wanted to try out porting on that and it worked out well. i port matched the aluminum insert on the rubber between the carb and the head. and i do realize there is no power to made there haha. its easy enough to keep a good shape by just taking your time. i used an air die grinder with a fairly aggressive bit. I would invest in a more mild bit if i was to do my own bike. anyway Id love an insight, techniques.. etc.. if everyone thinks its a job for the pros then chances are i wont do it :P but if i do end up doing it i could take some pictures and lists tools and types of bits if that interests anyone.
on a side note- if anybody has the 300 kit for the 250 what kind of jets are you running?
Thanks in advance
I have my 06 TC250 ported by a pro and he said there were gains to be had in the intake side. Cleaned up around the valve pocket and stem area. I had a 300 kit installed and the same time so not sure the gains but that bike ripped.
