difference between te 310 13 and 14
Jodi
hello,
does anyone had installed an athena get ecu on a te 310r? there are two modells for the 13 and 14. are there any differences between the maps or cdi ? i thought the 14 th has only new plastics?
thanks a lot for your support
achim
spigot off of fuel pump went from plastic to a alumnum. the alu one can be retrofitted. the electric starter gearset was made to spin the motor over stronger in 2014.also graphics changed. Dan
German Goldspeed rims in the US also. I believe the '13 still had Excels... maybe not. Open or closed cartridge forks- take your pick. possible minor wiring changes (color?)
shit... this is just a cut 'n paste from my personal notes:
differences from 2013s:
BNG (and why are '14s badged the "110 year anniversary" edition?)
black Goldspeed rims- not Excels. The Goldspeeds are nice.
updated fuel outlet. This just moved the breakage problem to the fuel line.
hardened starter gear.
possibly TC fork internals. This is still a mystery.
Tires?
final gearing 14-40 (blahh)
oil drain bolt (8mm allen; the 13s may have had this)
wiring changes (a few maybe; color changes?)
I think- but do not know, that all '14s were built in the summer of 2013.
