Dead electric starter.
Peluo
Bike have been stored for over a year. TE 450 2006. The battery have been on a tender. It won't crank or do anything. Could it be the switch? Or some type of fuse? I used jumper cables so it's not a week battery since it dosen't even atemp to start. It could be a wire or a starter that is stuck?
Is the kill switch in the correct position? I can't tell you the number of times I've tried to start a bike only to find that I had the kill switch on. :)
Might be the clutch wiring slide both leads off the end of the underside clutch body and tape together.
Good chance it will now fire up.
