Dashboard kill switch problem?
Jody Stewart
Hi everyone, new to this forum, looks like a cool place if you own a husky!
I've just bought myself a 2011 te250. Just ridden it for the first time today in an enduro.... It's absolutely mega, I love it.
Quick question though. I've got back and washed it, and now without the key in the igntion, with the kill switch pushed in, the dashboard stays illuminated! If u let the switch out, dashboard goes off. Push it back in, it comes on again. It doesn't start the fuel pump whirring it just illuminates the dash
The only other thing is that the fuel light is also on. It is probably low on fuel though.
Is the fuel light being on the cause of the kill switch turning the dash on ? Or is it most likey that I've got water in it?
Any help much appreciated
Thanks
Jody
This sounds like the same problem I'm having with my bike! Does your dash cycle through the numbers and go on and off? and will it start with the key turned on?
It doesn't do anything out of the ordinary by itself, doesn't flick on and off etc.. Yes it starts perfect with the key in.
Think I need to get some fuel in it to eliminate the fuel light.
What does yours do?
Mine does that after a wash also, no matter what the fuel level is.
I have tried dielectric grease on the electric connections, covering the dash/killswitch when washing and even unplugging the fuel sensor while its happening.
I just push the killswitch now and forget about it, it comes good once dry :)
If you find a solution please post up :)
Thats Cool then, thanks for the reply. It's put my mind at rest. I went to it this afternoon and its not doing it anymore.
Spoke to the guy I bought it off too who is a Husky dealer. I only started saying the words 'I've just washed my bike' and he finished off the rest of sentence by saying 'has your dash come on' so I guess it's a common one. I was considering buying a cheap leaf blower to dry it off once I had washed it!
I can't believe the damage I inflicted on it at the weekend in 3 hours of enduro riding! It was completely mint before I got hold of it. It now has a broken fork guard, bent clutch lever, a bolt missing from the seat subframe, bent radiator, lots more scuffs and scrapes. I only dropped it a couple of times
