Cylinder Studs - Fitting
grouty
Auto Lover ...
The studs in my 390 Auto motor were loose when I got it. Now the cases are re-painted I need to fit the studs back in.
Are they fitted dry, with a little lubricant or with a thread lock ?
Don't need or use thread lock. I use a little lube. If the studs can't be screwed in tight (wobble) then the threads need to be replaced using Wurth Time Sert or other engineered thread repair system. I wouldn't use helicoils on cylinder studs - they are fine for light duty. Good luck with the 390 as they are a great engine.
Thanks for the info. I guess a tiny smear of coppaslip grease will do the trick. The studs are a nice fit in the cases, so hopefully no inserts required.
I love my other 390, so can't wait to give the Auto a blast. I guess there will be many more daft questions as the engine build gets underway.
Usually the cylinder studs are removed and installed by heating the case to about 250F. That way when the case cools the material shrinks onto the stud and 'hugs' it in place
