cylinder head torque
I'm sorry I do not understand. What is cylinder stud torque (85 cr 500) ?
according to the page from the manual above, the nut is 29 ft.lb, screw is 25 ft.lb plus loctite 222. are you asking aabout the actual stud itself?
6 nuts hold the head on, 4 are on the long studs from the crankcase and two are from short studs in the barrel itself. make sure the nuts dont run out of thread on the short studs b4 the torque is reached. plenty of seizures from that little chestnut
its the 250 that has short studs
both of my 500's have capscrews head to barrel
