Seems spot on. Wish they would have tested it in power up mode.
http://cyclenews.coverleaf.com/cyclenews/20110510#pg46
hi im new to this forum and i am also a proud new owner of a 2012 te449 and i keep hearing people talk about this power up plug/mode. what is this and how do i install/turn on? please replySeems spot on. Wish they would have tested it in power up mode.
thank u motosportz for the info i found the plug and plugged it in and now it says race map2 on the dash and wow does it run much better p.s. i love this forumthere is a small plug that should have come with the bike. You plug that in under the seat up by the ECU and it adds fuel (richer) and makes it run WAY better. When your bike is running does it say "race map" on the display? If so your already in power up mode.
A fair review. Pretty much mirrored my initial experience with the bike. Now they just need to power it up and dump the Karoos.
one more question when i took off the ugly canister thing off the side of the bike i plugged the hole coming from the motor and the one that came off the gas tank im thinking i shouldnt have plugged the one off the gas tank cuz now the gas tank cant vent. what should i have done instead leave the gas tank part open?No problem.
At some point and if you add an open exhaust get the JF EFI tuner. You will find about that same jump forward as going for stock to power up as you will from power up mode to the JD EFI tuner. Makes the bike run even better and more power. Swap out the muffler and add the JD and hold the F on.
