CS sprocket c-clip Q
EricV
Hi all- this should be a quick one.
Later this week I'll be replacing my CS sprocket. Is the large c-clip holding it on reasonably easy to jimmy off or do I need to get a c-clip tool to do it? Though low road I know, in the past (w/ c-clips in general) I've wiggled 'em off w/ screw drivers. This one is big and looks sturdy, so not sure if I should spring for the proper tool (won't be switching back and forth, so not inclined to buy a tool for this.)
Thanks!
I've done it both ways and a circlip pliers makes it much easier. The proper tool is only a few bucks and worth it. Harbor Freight.
BTY, I keep an extra clip ready should the original clip break or shoots off into space. You might think about the same.
Sound advice. I'll see if I can pick one up locally. I like harbor freight, but really wanting it back on the road by the weekend for a ride so ordering one now may not work out. Thanks for the reply.
Edit: just looked up a local place on-line that has the pliers and you're right they are cheap, so it's a no brainer...I'll pick 'em up to reduce the likelihood of screwing up my circlip.
