grouty
Auto Lover ...
I am about to press apart the crank for my 390 Auto. Having a look through the manual, I found this -
I have checked the measurement "B" and it is spot on at 51.97mm
But I don't understand the last paragraph "On Automatics shall the right crank shaft be positioned 1mm from the level position"
Is this refering to the gap on the big end (end float) ?
The end float I have is .37mm
If I am supposed to have 1mm "from the level position", then something is wrong as to gain the .63mm required would put the overall width up to 52.6mm.
Or am I reading this all wrong :-)
