CR250 LC losing water out of overflow?
darren7878
Once bike gets up to full operating temperature its starts to lose some water out of the overflow.
Cannot find anything wrong, have rebuilt the water pump now but problem still exists.
Cannot find any water locks, whole of radiator is hot.
Was thinking about swapping the radiator cap but has anyone got any other ideas?
The overflow pipe is just in this picture.
Bike did around ten minutes here then I took picture
Funny I just went and swapped the head gasket out. It was new but I was worried.
Then I see you guys mentioning it too so maybe we are on the right track!!!
Old gasket looked wet so I'm hoping the one I put back in is better.
I will run it up and take a known good cap with me .
On head gaskets in the past I spray them with the permatex Hi-Tack sealer. I did this on cars, trucks, high performance engines. They never had a head gasket go bad. I never tried it on a LC bike yet. I soak the head gasket on both sides and assemble.
noticed you have the original straight clutch arm, if you switch to the liquid cooled arm it has a z shape that has better alignment and gives easier pull. most lc engines have this or phil has a ss one for sale. i believe there was a "husky products" one for sale also as a retrofit but it was just an lc arm
try swapping the cap for sure. if its a good cap i would start thinking head gasket. very likely the cap
Husky radiator caps are a lot higher pressure that others but look the same.
Husky caps from memory are 1.1 or 1.2 bar [ bar is 14lb about ]
I have fitted a 11lb cap and the coolant pissed out.
Your using old head gaskets?
Hi Bill - the top end has been off and rebuilt with new gaskets but something appeared to be a miss. Thinking the new gasket was compromised I took a risk and about an hour of spannering and fitted an 'old' gasket that I had.
The old gasket I refitted measured out at 1.2mm the new one that appeared to be no good was 1mm.
I only used the old gasket as I have some time constraints. The bike needs to be ready for a meeting that's looming up very soon
That sounds very interesting thank you
Do you have any pictures of what I need to buy??
http://www.husqvarna-parts.com/catalog/item/3736875/7315678.htm
this one is brand new and ss, but the oem 85-88 are steel and the same shape. you can also bend yours to get the angle but i believe that ends up making it a tad shorter when its done. i have one of the ss units and its a nice piece that i imagine would be resistant to wear
