Could someone put a meter on the Brown with black stripe wire from the temp sensor
OlderHuskyRider
'08-'10 310-450-510, there are 2 wires from the plug into the Water Temp Sensor (WTS). One is Black and it's a common ground among several sensors. The Brown with black stripe wire runs from the WTS plug to the ECU. Take your plug off the WTS, stick a straight pin or other thin wire into the plug for the Brown/black wire, and multi-meter that to a ground. I am getting 1.00-1.05
I thought my WTS went out last week, but now I have issues again: fan not coming on, hard starting when cold, I have replaced the WTS I replaced last week and no help.
Also, my WTS readings are difference from the norm, I am getting the following meter readings from brand new sensors, measured on the bench, off the bike:
80f - 1.75
84f - 1.50
172f - .26
Also, my WTS readings are difference from the norm, I am getting the following meter readings from brand new sensors:
80f - 1.75
84f - 1.50
172f - .26
I DID do those readings on the bench, just the temp sensor, and I think HUSKYnXJnWI did his readings on the bike.
EDIT:
I did the meter test on the WTS while hooked into the harness, came up with .640, which is in-line with HUSKYnXJnWI's reading at room temp.
