Dan888
"09" TE 250
Doing some maintenance over the winter, and addressing an issue i found last summer. It seems that the end of the adjustment bolt that is inside the swingarm is gobbed up, probably rusted. Googled it and found at least one mention of something similar, basically it was a tip to take these bolts out and coat them with anti seize before it becomes a problem. LOL, well I'm past that point i think. Both bolts move freely in and out , but only out so far before they get tight. I don't want to keep turning them and damage the aluminum swingarm. Thinking someone on here may have a tip. ? I have a couple ideas, One is to cut the head of the bolt off , cut a slot in the end and then run them on into the swingarm and let them rattle around forever. Replacing them with new ones from the outside. the other idea is to go ahead and wrench them out or drill them out and then tap the hole for a larger bolt. Anybody got any " more smarter" ideas?
Thanks, Dan
Thanks, Dan
