Converting 610 to 630 ?????
Blazes
I heard someone mention that it is possible to slap on a 630 barrel and piston on to the 610 as the crank is the same. Told i would have to gas flow the stock 610 head ? Anyone done this before ? Waiting for the agent in SA to confirm if this can be done ----
head, valves, timing chain and chain tensioner are all different in addition to the piston and cylinder.
I know the head is different -- but the importer who often spends time in Italy at the factory said the stroke is the same and the 610 head may be used --So if he is right it will just be a cylinder and piston replacement --Not looking at the head will just be flowing the old head. Maybe -- just maybe -- holding fingers crossed -- Or can one use a oversize piston to up the bore a little -- not wanting to do cams as my sm610 revs well.
I'm guessing the 630 piston and cylinder from your Eddy Seel Replica would work on a 610, as they have the same top end. I'm not sure a twin cam 630 would work.
My eddy seel has a spacer under the cylinder and a longer stroke i noticed -hehe not going touch that baby for my sm 610 :D
