390Dave
While looking through some old part catalogs tonight,I stumbled upon the specs of the 1983-1990 Yamaha YZ490 connecting rod.The YZ/IT 465 and WR500's might use it also.Although it is 2mm longer{at 137mm} than most 1975-up air cooled 250/360/390/420/430 rods,it does have the same 25mm diameter X 64mm long {would need to be shortened}crankpin,and uses the same diameter 18mm wrist pin.22mm small end bore.Small end might be able to bore and bush to 135mm.Width at big and small end is reported as 20mm.Looks compact enough to rotate without contacting the cases.Wossner does make pistons from 83mm up to 86mm for 390/420,with 35mm{8249DA series} compression height,2mm shorter than stock,which is 37mm.With the supply of original Husky rods and Eurorods{not available} about to dry up,it might be something to consider.On most engines,you might be able to juggle cylinders,heads and gasket thickness to get the deck height and squish established,or a 1mm thick spacer plate.I have seen some factory stock 390's and 430's over the years with the piston more than 1.5mm down the bore at TDC!!Some further searching shows that guys are running this rod{modified to fit} in 490 Maicos,without incident.Tomorrow I will try to measure the big and small end width of a stock husky rod,to see how it compares.
