Bigbill
Does early 70's 250cc, 360cc, & 390cc/420cc use the same connecting rods?
The rod crank pin and lower journal are narrower on this rod.
The early 250cc mag engine is totally different with a shorter rod.
The newer 82 cases take a longer crank pin and the lower rod journal is wider. The 250cc and 430cc rods are the same. While the 500cc rod is longer.
I'm just trying to understand here on the journal width and crank pin length and the difference between the rod lengths. With the older 70's cases and the newer 80's cases.
