Code question 2012 TE310
vntgmx
Have to take my '12 TE310 back to the dealer but was wondering if anyone knows what a "E41E" code is. That's what comes up when I turn the key on and it cycles thru on the speedo before the fail message comes up and stays on.
It is just the standard diagnostic code. Mine has it and it's not a negative code.
Possibly you have a bad connector that replaced the lambda. Hopefully it is a small item like that.
The E41E is normal to show up when you power up. It should disappear in about 1 second. Which it sounds like it does for you, but then you get the FAIL? Are you trying to start the bike before the speedo has fully booted?
I can get a FAIL on my speedo if I just quick tap the start button. But it'll start normally if I hold it down and clear the FAIL. I can't remember if I have to power cycle to clear it or not, though. It doesn't happen very often.
No I wait till it goes thru the full cycle and then all that appears is the MPH and "Fail" and that's how it stays. Rode it like 20 miles yesterday and "Fail" was there the whole time and all you can see is your MPH and the "Fail". Bike ran fine so I'm sure it can't be anything big but I'll find out in the next day or two when I get back into the shop and they plug in their diagnostics.
