clutch
richard kersten
Had to bring my bike back to the shop today , clutch not disengaging , wants to learch forward whe trying to start in gear and when I shut it off and put it in gear pull the clutch and push it I can feel it dragging , glad I got the extended warranty .
We run Mobil1 0W40 euro formula for everything, including our 2 stroke transmissions.
Clutches are normally very robust a small air lock will diminish the clutch throw. I know you have probably bleed her from the slave. Perhaps try to reverse bleed by pumping in the fluid from the slave up to the reservoir. Take some fluid out first.
Failing that make sure your clutch springs are in tight.
