EricV
Hi Gang-
I don't think I've read anything on here about this particular symptom....hoping someone can provide insight as this is my first hydraulic clutch. It's a TE630, w/ about 4K on it now.
The last two times I've ridden (but only when it's cold...first ride of the day and not after) I've started the bike up, let it warm for a brief moment (as it's warm here) and then take off. The thing is the clutch disengages like right away. I'm a two finger guy and usually I feel the gears engage/take off when the lever is about 2-4mm away from the other knuckles wrapped around the grip, but this is instant and then, from there, the rest of the lever travel feels very loose/sloppy. After the first 2-3 pulls/releases all is back to normal (engages at it's usual point in the travel and the rest of the travel feels normal.) It stays fine all day, until the next cold start up/ride.
I have the updated push rod, but have not installed it as I've not had issues. I also do not see/feel any leaks. No prior issues with the clutch system whatsoever.
Thanks!
Eric
Thanks!
Eric
