clutch slave cylinder problem
Moesgaard
I have a te310 from 2011, and the seal/bellow at the end of my clutch slave cylinder is broken. in the Husqvarna parts catalog there is only a complete slave cylinder 8000 A7048 . does anyone now where to get only the seal, its a brembo cylinder. after 2 hours of enduro riding oil gets to the clutch fluid, causes over pressure and the clutch slips, opening the breather screw and its good again!
Typically, there is not pressure in the motor strong enough to force motor oil into the clutch slave, the engine should be vented to atmosphere and not be pressurized.
I disagree on the no motor oil into the clutch slave, even with clearly vented motor my 690's slave cylinder/seal failed. Combustion byproducts like black sludge were evident in the lines and both the master reservoir and slave. I don't know about pressures but there is definitely the ability for engine oil to force back into the clutch system at least to the point of mixing.
Don't ask me how it happens but I have seen it happen before. They aren't too expensive to replace the whole unit, but if you could get hold of the seal its probably worth trying
