Clutch slave and piston??????
brian foster
so it finally went and need a new slave and piston haha where is the cheapest and best place to get a billet or stock piece???? ive been looking around but really cant find much just a couple but they are all lotsa money hahaha i polished the stock one and put a new oring which lasted quite a while but the tolerance is too far out of spec now and yea very sad haha
you laugh a lot while typing... haha
Stock- halls husky (but you knew that)
Zipty Racing- for the billet housing (should be able to use stock piston you have)-
7602- for their piston that fixes the problem of the stock piston tilting in the housing causing wear- (supposed to work with stock or zipty housing/ and may work with many worn housings- but obviously if its too badly worn it probably will not be able to resolve the issues.
I guess with yours- I'd probably lean towards getting a new stock housing and a 7602 piston...
I didn't have too much wear on my stock housing and got the 7602 piston and installed it- also rebuilt my Master Cylinder/ bled and I am good as new. It was loosing presure and recovering over and over and over- made technical riding very difficult. Problem solved.
yea my slave looks good the walls are not too bad just lost pressure last year rebleed the system and worked till last week then put a new oring in and yea worked for a bit and then lost all the mineral oil in the motor sooo haha im just going to try a new stock slave and piston kit and see if that works, did husky have a problem with the masters going bad? or just the slave and piston magura made? and yes im a happy person hahahahahahhaha
No real issue with masters but the seals can wear in time - not too common but it happens. $30 to rebuild the master. My symptoms were just weired and I didn't feel like playen' so I just did that too. (usually a leak at the master at the plunger lever is the "symptom" to look for but there's 2 seals, one to seal and one to push- I suspected my pusher was leaking...) haha:D
