Clutch Problems
huskyista
Does anybody know where I can find an after market clutch master cylinder for 2009 TE 250? The stock ones have that plating that comes off and causes leaks which can't be fixed by replacing the internal parts. :mad: I don't care if it does not have the mount for the clutch safety switch.
Thanks for any info
Master Cyl- at bars not slave at motor- right? No, well. Yea, you could switch to the Brembo System I would think...
But I haven't heard of the Magura's doing this.. and they have been used alot- been in KtMs for over a decade.. Maybe the one you got was bad? bad plating? So you went to replace the cylinder and spring and found chips and a poor bore- like corosion?
What were the symptoms like- was it random clutch pull /good then bad, or was it leaking from the master behind the lever plunger?
It's the master cyl on the bar, yes. A leak developed. Upon disassembly, I found that the plating had come off of some of the internal bore. Replacing the guts, didn't stop the leak. The clutch works fine.
