Clutch lever switch?
BiG DoM
Mine on TE610 giving shit! Looks like the pin is worn ... I presume it should stick out the end of the switch but is virtually level. Is really an idiot switch like a sidestand switch IMHO. What do most do - bridge it out or replace?
I think all it does is stop you from starting the bike unless the clutch lever is pulled. I'd just bypass it if replacement isn't an option.
Simply cut the wires leading to the clutch lever switch, strip them back, solder them, and cover with heat-shrink tubing. The circuit will then be closed and the starter will work without interruption.
Does the switch still work, or is it just that the lever doesn´t depress the pin? The bevelled nut on the brake and clutch levers sometimes need to be adjusted slightly. If the switch is dud, a replacement is cheap (scooters etc. use the same part so it´s freely available). Or you could just connect the two wires. But this could be seen as an "alteration" which might affect safety issues and cause problems with insurers etc.
