Clutch lever replacement suggestions?
TyWaugh
I broke my clutch lever and before I replace it with the same, I was wondering if there is a lever that will give me a little more leverage and make the pull a bit lighter. I have searched the web but not finding anything specific. Is there anything you guys would recommend?
-Ty
If Midwest Mountain Engineering has a lever that will work with the 2013 clutch, I would recommend them. I have one on my 2009 that I'm happy with.
They do have a lever for Brembo clutches, so I expect that would work. Only thing I'm unsure of is that they list a special model for the KTM 350, and a regular model. Presumably ours would be the regular model, but it doesn't specifically say on the website:
http://midwestme.com/pages/productspage.html
Same as Andrew ,I have had one on my 09 310 for over a year and it makes feathering the clutch real easy . I damaged the rod in mine , called them and they were very pleasant to deal with .
Put an MME lever on my 511 after turning my ASV lever (and handguard) into a pretzel. It's a right pain in the arse to adjust and get it bang on, but goes alright once it's set properly.
I've been using MOOSE replacement levers that I picked up from the local KTM dealer. Hell of a lot cheeper than Brembo. Take your Brembo with you to make sure the plunger matches up.
I did this too, but ordered online. I found I had to shim the pivot a little to reduce flop. Otherwise works perfectly, and inexpensive.
