Clutch lever question
RJ Bell
i have a 2009 450 smr and it has the hot start on it above the clutch lever. can i still put a shorty clutch lever on it? anyone have any good clutch levers in mind, i was looking at righteous stunt levers.:cheers:
I would think you can replace the clutch lever, I just sawed my OEM lever off to make a shorty out of it.
I think the lever above the clutch is a compression release.
I usually make my own custom levers for all my bikes. Cut the lever down to the size you want. Then grind some divits into the cut tip. Go buy yourself some JB weld putty. You can mold yourself a curved ball onto the cut end so it looks professional. Once it dries, just sand it down smooth and paint, or have it plasti-dipped. Comes out great and saves you a few hundred dollars on those absurdly priced replacement levers.
I'm not sure how you're saving a 'few hundred dollars' on a lever that costs $65, but all the power to you, if that's what you want to do. The other difference with the MME lever is that the pivot point is also changed, so the clutch pull is lighter. Of course, the throw is a little longer, so some may not like it that way, but it works great for me.
